3rd fuel line ?
psychochild187
Post Sat Aug 22, 2020 9:00 pm
hi everyone . i've not been here in AGES as my E30s been dormant for so long .
but just getting her ready for mot , there's the normal things i've lost broke and cant remember where they went
i replaced the x 2 fuel and brake line to the rear. and a larger pipe .i think for the breather. BUT in the engine bay its loose and ive no idea where it used to go ?
the other 2 fuel lines are in place but not this last rubber hose
325i G reg convertible
any help welcome
Post Sat Aug 22, 2020 11:39 pm
Leave it exactly as it is , with the end of the hose tucked into reinforcement for the suspension turret.
IF your car had a cat. and other emissions equipment, it would connect to a carbon canister (big round knockout plate in the area behind the bumper mount), then to a solenoid valve (unused plug hanging from the wiring loom that goes to the AFM), and then on to a connection into the inlet manifold, under the throttle body, right next to the TPS. This connection is unused on your car, and must be blanked off with a small rubber cap. This cap perishes with age, and it's worth checking that it's there and intact.
acme15
Post Sun Aug 23, 2020 8:06 am
I removed mine completely because it was in the way of my sill repair and I never put it back.
But it used to be poked into the front chassis leg.
Post Sun Aug 23, 2020 10:01 am
There's no reason why it shouldn't be removed back as far as the rear of the car, as it was on pre facelift cars. The open end should positioned on the LH side of the car, however, to help prevent fuel leakage if the car ever ends up parked on it's RH side.
psychochild187
Post Thu Aug 27, 2020 12:32 am
thanks for the answers guys. i did what you said. i didnt think i unplugged it,
the hose was dirty on the inside like it was never attached. shame i spent 40 quid in copper nickel pipe i didnt need lol
