Not sure if you'd consider this damaged?
I can't be arsed sending it back for starters but guess I'll do what I need to
New rad damaged?
RKB
I would send it back but , if you cant wait then try and pressure test it so at least you know where you stand.
It looks like just the ally fins so it is likely to be ok but my eyes are old and bent.
e30-EVN
I'd send that back yeah to be honest mate
A 2 door e30 with 8 cylinders, what could be better
RKB
Thought as much, ballache as I'd thought I would have it up and running by now...
Damaged on the other side as well, this is my second one!
flybynite
Ukhozi
Had to get my new one from Schmiedmann in Denmark as it is a rarer pre-facelift automatic one with the lump on the top for the breather. It arrived with a couple of bent fins but all in all it's OK, why they don't slap a sheet of hardboard each side instead of cardboard I'll never know, cheap I guess. try asking the sender to extra protect it?
Everyone has the right to reach the level of their own incompetence.
RKB
I'm just going to go in store and swap them, seems to be common at least with Rads.
flybynite
I've had a few rads and two aircon condensers shipped direct from Germany by Autodoc recently and so far they have all arrived completely intact.
Hella/Behr and Nissens do pack things quite well though, not sure it is the same with other makes though.
ECP did ship me a fuel tank and it arrived with worse dents than the one coming off
