So my check panel alerted me to a failed dipped beam. Sure enough, left front is out.
So I switched the bulb out... but it still didn’t work. RHS dipped beam is fine though.
I metered the plug... 0 volts. So I tried a spare relay... still no LHS...
Before I dig deep and start stripping the loom back are there any common failures for this?
Clearly there’s a broken wire / dry joint somewhere.
Left dipped beam not working
Radar
E30 M3 Convertible
911 Turbo S
CLS63 Shooting brake
911 Turbo S
paultv
I assume you've checked the relevant fuses?
Paul:-)
Paul:-)
