Aerial
RTTBMW
Post Mon Jun 22, 2020 8:01 am
Hi,
Anyone have a solution to why the aerial does not go down fully! If not can you get a direct replacement and where! The last top piece does not go down to close the aerial.
regards
Richard
E30 325i Mtech 2 1990 (Registered in 1991)
Sleepless
Post Mon Jun 22, 2020 9:06 am
This should fit: https://www.ebay.co.uk/itm/BMW-3-Serie- ... 1040370805
I advise you to contact the seller first to ensure compatibility.
flybynite
Post Mon Jun 22, 2020 9:45 am
Yep if your car does not have a Hirschmann 2050 then that is what you need
Ozu
Post Wed Jun 24, 2020 1:04 pm
I bought a cheapo one off eBay, fitted about 10 years ago, and it works perfectly.
flybynite
Post Wed Jun 24, 2020 1:46 pm
Lots of cheap things work, but if you are spending a lot of time, effort and money putting a 325i Sport back to the way it should be then a Hirschmann 2050 is what should be there.
biffer
Post Thu Jun 25, 2020 12:26 am
Have you tried WD40 on the mast?
RTTBMW
Post Fri Jun 26, 2020 7:56 am
It goes down if I apply my hand on the areial as it is going down. Bought a new one now but will try WD40 on the weekend!
regards
Richard
flybynite
Post Fri Jun 26, 2020 9:32 am
Would't really use WD40 as it can get rid of the lubrication that is there and affect the plastics and rubbers inside probably making it stick. WD40 is not a lubricant and may leave a residue that gumms things up further.
If it is a cheap aerial it doesn't matter but some electric aerials are NLA and eye-watering money to replace so need looking after.
I would clean it with alcohol and then re-lubricate it with something like a silicone spray. Even better Hirschmann do the proper stuff like wipes and lubricant.
With most good aerials the mast can be replaced easily if needed without replacing the whole thing.
I'll stop here before Satan starts on what he lubricates his mast with :roll:
RTTBMW
Post Mon Jun 29, 2020 2:22 pm
I did not get fitting the aerial yet as I had to replace fuel pump on my Regal 2450 which has been in storage for 4 years! But will look at doing this next weekend. I'll try alcohol to clean the aerial as the house is coming down with the stuff.:-)
