tailgate locked fcuked?
fuzzy
hi folks,how do i get into my boot as the lock has stopped working? ive taken of the panel inside as i was going to remove the lock and catch but i cant seem to get into my socket into the bolts.the central locking solenoid is working but doesnt seem to be connected to the catch,i take it there is something meant to be connected to the hoop on the end of the solenoid, but what?
Take it this is a touring?
Pull off the panel that covers the rear wiper motor etc. Held on by the same kind of clips that hold door cards on.
You will now be able to unscrew the loop on the tailgate that engages with the lock mechanism with a 13mm open end spanner.
Now that the tailgate is open, remove the trim panel that covers the inside of the light clusters, and unscrew three 10mm bolts that hold the push button mechanism in. You will also have to unscrew the locking solenoid and unhook its wire link.
Once the button mech is removed the rest of the lock just falls out, and you can then work out what has gone wrong.
Know all this in detail, 'cos I've just spent the afternoon refitting it all to a rear ended touring that I've just straightened out.
fuzzy
thanks brian,it is indeed my touring,the key/button pushes in but doesnt turn.... ill get onto it in the morning
