LSD centre in a small case diff?
Lemon98
Post Fri May 15, 2020 2:17 pm
Quick question here and asking for a future purchase..
Is it at all possible to put an LSD centre inside of a small case diff? I only ask because I currently have a 4.10 ratio SC diff in my 320 and I really like how it drives, I feel it suits the car perfectly and I don't want to go to a longer final drive.
OR vice a versa is it possible to put a 4.10 ratio ring and pinion onto a medium case LSD??? My guess is that the small and medium cases have different sized pinion wheels?
Thank you :)
1990 4-door 320i SE
flybynite
Post Fri May 15, 2020 5:18 pm
It is because my 323i has one and I think they were and option in the 318is. A 318is LSD was 4.10
Lemon98
Post Fri May 15, 2020 9:28 pm
As in to buy an aftermarket centre for a 318is as this wiki page https://www.e30zone.net/e30wiki/index.p ... tial#Ratio says it was open from factory.
I'll have a search for 318is diff parts thank you!! I hadn't thought about the is
1990 4-door 320i SE
Post Sat May 16, 2020 9:40 am
Medium case diffs in 4.1 and LSD are out there but I would expect them to cost more than the small case version, although if you are going to pay someone to rebuild your diff it would probably cost more than buying a medium case lsd ready to go
hennabm
Post Tue Jul 14, 2020 9:46 am
My 323 came with a factory small case LSD with a ratio of 3.25. These will be very rare I would think by now.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
