Auto vs manual idle speed
BristolE30
Post Sat Apr 04, 2020 11:58 pm
Hey zone,
On the hunt to fix my rough idle problem I noticed this in the Bentley manual - It says the manual idle speed is higher at 850rpm rather than the 750rpm for auto, is there something I need to swap out now I've converted to manual to achieve this 850rpm?
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
Post Sun Apr 05, 2020 10:39 am
Carb. M10 engine? Still on original carb?
BristolE30
Post Sun Apr 05, 2020 12:42 pm
Brianmoooore wrote: ↑
This is for my 325i 88, just competed a manual conversion. Idle wasn't great prior to the swap anyway, so I doubt this is the issue, but I just noticed yesterday in the Bentley manual it saying that idle speed is different for auto and manual. Now that I've converted to manual, is there something I need to replace electronically to increase it to this 850 rpm idle speed?
BMW E30 316 ‘87
Bristol, UK
BristolE30
Post Sun Apr 05, 2020 12:43 pm
Ah I see what your saying - this is for the 4cyl cars isn't it
BMW E30 316 ‘87
Bristol, UK
Post Sun Apr 05, 2020 1:42 pm
BristolE30
Post Sun Apr 05, 2020 3:18 pm
On another note I just tested my ignition coil between king terminal and the 15+ and resistance is reading 5800 ohms. Is this a bad sign?
Terminals -1 and +15 reading 0.6ohms
BMW E30 316 ‘87
Bristol, UK
Post Sun Apr 05, 2020 4:26 pm
Sounds fine to me. The most likely thing to go wrong with it is a few shorted turns on the secondary which won't make much difference to the resistance anyway.
