Hi I have a electric roof on my convertible and the usual issue with the main motor,where it shear away and bends the bug bar.
I have bought the reinforcement kit to fix this issue. Is there anyone on here that can put it all back together and do any needed adjustments etc to get it all working again. If so how much would you charge?
All help much appreciated.
Convertible roof help
BenHar
Some stuff in the wiki about the electric roof here: https://www.e30zone.net/e30wiki/index.p ... #Cabriolet
Ben
Ben
guss300
I've seen that thanks but not helpful with my issue
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
Hi, Have you fitted the repair plate and the motor? What tends to happen with things break is the bars bend out (apart from the main motor's securing points getting broken). However, it is a simple case of bolting in the new bars and testing it.
What stage are you at?
guss300
Hi I've got the reinforcement plate and new bar just waiting for the gas struts to arrive for the horseshoe
Gert_8
Have you fitted the repair plate and the new bars? I have asked you this before.
It's been a while since I looked at the mechanisms, but I don't recall seeing any gas strut... I could be wrong and simply cannot recall seeing them.
Any pics? They would be a great help.
BenHar
There are gas struts to assist the raising of the roof.
They are hidden down near the hinges.
I suspect that they're all fucked by now.
Ben
Ben
Gert_8
Cheers Ben. Wow, I don't recall them at all. I'll take another look when I can!
Radar
Cayman autos in Redhill (Surrey) sorted mine out. I highly recommend them
E30 M3 Convertible
911 Turbo S
CLS63 Shooting brake
911 Turbo S
