Sorry itβs probably been asked a lot and I have looked but canβt find a definitive answer.
What should the plug gap be on ngk bpr6es?
And are these even the best plugs for my 1990 320i?
Thanks wayne
320i plug gaps?
reggid
catted engine BOSCH W8LPR/W8LCR
non catted BOSCH W8DC
according to BMW.
i'd get the NGK equivalent as the plugs are better than Bosch (run cleaner with less deposits)
quick google suggests these are the equivalent NGK.
NGK ZGR5A for the catted (these have projected tip) same as the M20b25 8.8:1 (catted plugs) which work great
BP6ES/5ES seem to be the NGK equivalent both appear to be non projected non resistor. I would have though the BP5ES would be the correct heat range though.
BPR6ES is only what i'd use on a higher compression engine >9.5:1 that's going to be custom mapped.
according to BMW.
E30 325is with M20B31
WaynE30
Hi thanks for the reply
I went with bpr6es as e30 wiki suggested it.
Do you know what the gap should be ?
reggid
its around like 0.7-0.8mm doesnt matter much, still runs fine at 0.9 or slighty more the stock ignition setup is pretty good
TheWolfman
Lemon98
reggid wrote: βMon Feb 03, 2020 3:09 amcatted engine BOSCH W8LPR/W8LCR
according to BMW.
I've got some WR8LC's on order for my 320i which still has its cat but I haven't had the car for long so not sure if I'll be able to notice any difference.
Can't remember what is currently in the engine from when I checked their condition but I will post a reply updating that when I swap them in!
Also when you say that BMW recommend a different plug for non-catted engines I'm guessing you mean from factory right as if I eventually remove my cat I shouldn't have to change to a different plug should I? Like apart from back-pressure I'm not sure what else would change in the combustion chamber (unless back pressure keeps more/less exhaust gas in the cylinder and thus increasing/reducing the in-cylinder temps?)
1990 4-door 320i SE
Lemon98
1990 4-door 320i SE
Pardon?? You've lost me there!
The one type of plug you shouldn't run a M20 on is four electrode plugs. M20s don't seem to like these at all.
reggid
The different heat range is due to the change in compression ratio. the non catted engines have a higher CR so need a colder plug at least for the M20b25 this is the case. i dont know much about the b20 and variants.Lemon98 wrote: βThu Feb 13, 2020 7:27 pmI've got some WR8LC's on order for my 320i which still has its cat but I haven't had the car for long so not sure if I'll be able to notice any difference.
