Antifreeze type?
jmec
Post Wed Jan 22, 2020 6:13 pm
There's a number of antifreeze options available. What type is best for a 325i. Thanks in advance.
biffer
Post Wed Jan 22, 2020 9:53 pm
I run modern pink stuff (5-year) in mine with no problems.
I made sure i flushed all the old blue 3-year stuff out properly first.
boiliebasher
Post Thu Jan 23, 2020 10:33 am
Agreed. I personally don't think it would make much odds which one you use, just as long as you don't mix them up.
reggid
Post Fri Jan 24, 2020 12:43 am
just buy the BMW stuff
E30 325is with M20B31
AuroraMagic
Post Sat Jan 25, 2020 1:45 pm
The BMW E30 Bentley's manual recommends (in summary) :
Use only BMW approved phosphate-free anti-freeze .
Usign phosphates can harm the cooling system (and may void arranty). :D
Post Sun Jan 26, 2020 11:22 am
I would personally steer clear of OAT antifreeze and stick with the blue stuff. I did use the pink stuff some 12 years ago but the next 5 years that it stayed there I could smell inside the car when the heater was used a slight whiff of antifreeze. When I went back to blue stuff the smell disappeared!
A couple of years later I suffered water mixing into oil and turned out to be head gasket. The head was found to be ok during pressure testing. I have an M10 engine which generally should not have head gasket issue.
Last month I had a cam belt changed on an E36 with m40 at a BMW dealer and the dealer used the blue stuff for antifreeze. So I would go by what BMW use to avoid possible future issues.
tha881
Post Sun Jan 26, 2020 12:10 pm
I used Fuchs Fricofin Esk, its phosphate free and the correct blue which bmw recommends
mickes
Post Mon Jan 27, 2020 10:37 am
Yes I definitely agree with not using oat and sticking with the blue. I used the oat in my E36 compact and couldn't make out why I kept getting a leak from the seal on the elbow at the back of the cylinder head,turns out that it is not kind to certain types of seals which I found out after searching the internet. I always use triple qx blue for both my E30 & E36. Don't have any more problems.
