Hey guys,
Wondering your thoughts. I’ve been wanting to fit a cone air filter for a little while to get some more air into the engine and I’ve heard it’ll sound nice. obviously I’ve seen and heard from a few people that it doesn’t make any difference at all compared to stock.
Is this 100% true, does it really make zero difference in performance? It seems in theory it should.
Cone v Stock Air Filter
BristolE30
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
For a 325i
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Cloggy Saint
Unless you build a heat shield around the cone filter it will lose power as it will be sucking in hot air from the engine bay. Even if you do this you're not really going to see any noticeable gains. The best option is to fit a 'performance' filter in the standard air box or just leave as is.
BristolE30
Why won’t there be any noticeable gains?Cloggy Saint wrote: ↑Fri Jan 17, 2020 11:40 pmUnless you build a heat shield around the cone filter it will lose power as it will be sucking in hot air from the engine bay. Even if you do this you're not really going to see any noticeable gains. The best option is to fit a 'performance' filter in the standard air box or just leave as is.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Cloggy Saint
This was a hot topic some years ago when the zone was at it's peak. Somebody (either here or independently) did a bench test, cone filter v stock airbox/filter v stock airbox/'performance' panel filter. The cone filter was judged least efficient and the standard set up and performance panel filter where pretty much the same. As Brian Mooooore often says, for something like airflow BMW got it right from the outset and improving on it is not very likely.
BristolE30
Interesting, good to know. Wonder if I can find it. Good to know BMW got it right hahCloggy Saint wrote: ↑Sat Jan 18, 2020 6:09 pmThis was a hot topic some years ago when the zone was at it's peak. Somebody (either here or independently) did a bench test, cone filter v stock airbox/filter v stock airbox/'performance' panel filter. The cone filter was judged least efficient and the standard set up and performance panel filter where pretty much the same. As Brian Mooooore often says, for something like airflow BMW got it right from the outset and improving on it is not very likely.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
reggid
a replacement K&N panel filter in the stock airbox will slighty outflow a stock OE paper but at the stock hp level the benefit will be extremely small
E30 325is with M20B31
BristolE30
Good to know guys thanks for the responses. I’ve bought a Bosch one, I know it’s not a performance one but hopefully work well stillBrianmoooore wrote: ↑Sun Jan 19, 2020 10:49 pmAND a decent paper element will actually filter the air.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
