Hi,
Only one bulb is working on the controls for the headlight dim control. What is the likely cause of not working! I did place a new bulb in but still not working! Which fuse is this likely to be connected to? 10 or 23? Maybe the bulb holder is knackered? Can you get these replaced?
regards
Richard
Bulb light not working in Headlight aim control on dash
RTTBMW
E30 325i Mtech 2 1990 (Registered in 1991)
BenHar
Can you explain which bulb you mean, please.
You have said "aim" in the post title and "dim" in the text, neither of which describe a bulb in the dash that I know of.
Ben
Ben
Cloggy Saint
RTTBMW
Its the aim control for adjusting the headlights. The 1 2 3 switch has dash bulbs either side of the switch. One of them works but the other does not!
