Gearbox cover?
Jazzjazz
Hi could someone please assist? I looked under my e30 (325i sport 1991) and noted that the end of the gearbox is 'open', exposed to the elements. Is this how it should be or is some sort of cover required? As per the photo. Thanks in advance .....
paultv
Looks like you're missing the bowl reinforcement item number 11141286342.
Maybe someone forgot to re fit it after having the oil pan off.
Incredible!
Paul
Incredible!
Paul
steve_k
no it shouldn't be like that at all, also get that flywheel seen to, it looks a little on the rusty side.
flybynite
As above, but I would also look at the clutch if the flywheel is that bad. Rusty pressure plate no good to anyone.
paultv
Also be aware that this is a structural item between the engine and gearbox.
Paul
Paul
flybynite
sweep
I may have one if needed
