Speedo not working
guss300
Hi my speedo is not working and the miles dont go up. Also the economy thing is not working. I have taken the clocks out and there are three wires that I dint know where they go see pic below and any help will be appreciated
Cloggy Saint
guss300
When I put my foot down the economy gauge sometimes works but not the speedo
guss300
The green wire was connected to the green plug somewhere on back of cluster but came out and dont know where it goes
As above!Cloggy Saint wrote: ↑Sat Oct 05, 2019 11:44 amHave you checked the plug and wiring on the diff? This is the usual culprit for a failed speedo.
Most pins on the green plug at the back of the cluster are a speed signal out of the instrument cluster, and feeds various optional extras, such as cruise control or speed controlled radio volume.
Wires to the speedo sensor in the diff are pin 8 (brown wire) and pin 12 (brown/red) of the white instrument cluster plug. The speedo. sensor itself is a simple on/off switch that operates several times per turn of the rear wheels.
