15mm Rear Spring Pads
TurtleDesignTech
Post Sat Aug 24, 2019 7:12 pm
Has anyone tried fitting larger spring pads in the rear.
I Googled around an heard over the years that 15mm spring pads from an E46 fit.
Bimmerworld even advertise the following part number for an E46 as being a E30 15mm spring pad: 33531094754
https://www.bimmerworld.com/Suspension- ... g-Pad.html
If anyone has tried this please let me know.
Post Sun Aug 25, 2019 10:12 pm
Not used any that thick, I have had some made from nylon though, just to raise the rear after lowering springs dropped it a little bit too much
