Slow front electric windows
ah
Post Sat Jul 13, 2019 10:44 pm
My front driver and passengers Windows go up and down very slowly,the passengers occasionally stops half way up or down.Ive never oiled or greased any part ,should I,or is there another reason for this.The rear windows are fine.
ChrisHC
E30Zone Contributor
Post Mon Jul 15, 2019 5:14 pm
You could try winding the windows using the emergency handle from the tool kit, if it is very stiff it sounds as though it could do with lubricating, if not the motors are bit tired after many years. I do not know if there is any guide to lubrication, but taking off the door card and plastic sheet, and then oiling or greasing anything that looks as though it might benefit is where I would start.
ah
Post Mon Jul 15, 2019 5:57 pm
Cheers for the info,I'll give it a go.
Contours
Post Mon Jul 15, 2019 10:04 pm
You might try lubricating the window frame rails that the windows sits in with Silicone lubricant. Friction created by the window rails can be part of the reason for a slowing motor.
ChrisHC
E30Zone Contributor
Post Tue Jul 16, 2019 12:15 am
Contours wrote: ↑
Yes indeed, well worthwhile.
