Does anyone know the torque setting for the top nut on the rear shock assembly.... Here it is on the photo
https://share.icloud.com/photos/0wiFJvP ... TlKmCl8UTg
And yes...that rubber was really perished
Torque setting nut rear shock top mount?
BenHar
Ozu
Thanks Ben, but I had seen that page on Wiki and assumed that the torque setting quoted referred to the twin nuts which bolt the shock mounting assembly to the bodyshell?
BenHar
It says: Rear Shock Absorber to Upper Mounting Bracket
Bentley says this:
Ben
Ozu
Thanks again , that is exactly what I needed to know.
BenHar
If you search the internet for "e30 bentley manual" you can download a copy.
Ben
Ben
Oseanosea
I bought the physical book, but no matter the format, I’ve found the E30 Bentley manual to be worth every penny! I think I found my copy brand new on eBay for around $40.00
“Keep lowering your standards until goals are met.”
