Help: Valve Adjustment Gone Wrong
ifinallyhaveane30
Hello everyone. I completed my fourth valve adjustment on my e30. I am having trouble getting the correct "pull" or "resistance" on the .10 feeler gauge when adjusting the gap between the eccentric and the valve. Does anyone have any advice? I adjusted my valves about 500 miles ago and was unhappy with a few of the valves ticking noticeably louder than the rest. I went in to adjust them all again, and seemed to mess things up even more.
Thanks!
Thanks!
arrisbmw
did you clean out the spray bar that lubricates them. I understand that is the weak, link top end lub on these engines .
ifinallyhaveane30
Steve
I gather you meant .010 and not .10 ?
webmaster@e30zone.net
paultv
BMW make a tool which has a pin to go into the eccentric and a spring on the end, this means as you bend the spring, it applies a pretty constant pressure to the valve/eccentric face as you tighten up the clamp nut with the feeler gauge in place - once the nut is tight, pulling out the feeler should have the right " friction" feeling, neither too tight nor too loose.
I made a rough copy out of a bent nail and a spring, it works really well, the spring is pretty weak, so bending it about 45 degrees gives the right pressure to the valve/eccentric/feeler gauge faces.
Paul
Paul
HJ1981
I have been searching everywhere for that tool, out of stock or no longer available keeps turning up.paultv wrote: ↑Wed Jul 10, 2019 10:39 amBMW make a tool which has a pin to go into the eccentric and a spring on the end, this means as you bend the spring, it applies a pretty constant pressure to the valve/eccentric face as you tighten up the clamp nut with the feeler gauge in place - once the nut is tight, pulling out the feeler should have the right " friction" feeling, neither too tight nor too loose.
Paul :-)20190710_113504.jpg
OP: The valves are very "loose", these M20s like "tight" valve clearances. I myself did the valves 3 times, and each time i made the clearance tighter, from sliding the feeler gauge "comfortably" between the valve to "snug" and slightly catching. Till now the valves in my M20 are ticking a bit, and i know that they should be nice and "tight", to the point that the 0.025mm feeler gauge is barely able to get clearance.
That is what i am about to do tomorrow at least.
Regarding cleaning that tube, i never came across that information be it in any manual or on the forums.
Steve
Don't forget to check out the E30 Wiki guide - https://www.e30zone.net/e30wiki/index.p ... M20_engine
paultv
You may also have pitted eccentrics - worn from years of use, so they have a "cup" indent from the valve stem top, which you "bridge" with the feeler gauge, so the gap, although correct, isn't, it's wider.
I set mine at the cam lobes, I used a 7 thou feeler which approxiamtes to a 9.8 thou gap at the valve ( rocker ratio applies here ) I have a new camshaft and eccentrics, the car is pretty quiet, but there's always one "ticker" !!
Paul
Paul
ifinallyhaveane30
The "feel" I got when I adjusted the valves was that it was slightly tough to get the feeler into the gap, but once in, it slid around freely. It sounds like this is not enough resistance. I'll try to fashion one of those tools. Thanks for posting a photo of it.paultv wrote: ↑Wed Jul 10, 2019 10:39 amBMW make a tool which has a pin to go into the eccentric and a spring on the end, this means as you bend the spring, it applies a pretty constant pressure to the valve/eccentric face as you tighten up the clamp nut with the feeler gauge in place - once the nut is tight, pulling out the feeler should have the right " friction" feeling, neither too tight nor too loose.
ifinallyhaveane30
To follow up, the loud ticking audible in the video was due to me not tightening the eccentric bolt down enough. The gap was enormous. I completed another valve adjustment and the car runs pretty rough. Sputtering, rough idle. Slight lack of power. Very light white smoke (or moisture??) coming from exhaust.
There was also oil deposits, residue, and ashy electrode. Seems car is running too rich. Anyone know what could be leaking into the cylinder? Am i totally screwed?
ifinallyhaveane30
A better question would be what seals would one recommend replacing to stop oil from leaking into the cylinder?ifinallyhaveane30 wrote: ↑Wed Jul 17, 2019 8:55 amTo follow up, the loud ticking audible in the video was due to me not tightening the eccentric bolt down enough. The gap was enormous. I completed another valve adjustment and the car runs pretty rough. Sputtering, rough idle. Slight lack of power. Very light white smoke (or moisture??) coming from exhaust.
Supafly
I had this issue on my m20 too. I would measure them and they would be within spec but I could feel the extra movement in the rocker, it was only when I turned them around to expose the contact face that I saw the pitting. New eccentrics (cheap at the time) fixed it for me.paultv wrote: ↑Wed Jul 10, 2019 12:28 pmYou may also have pitted eccentrics - worn from years of use, so they have a "cup" indent from the valve stem top, which you "bridge" with the feeler gauge, so the gap, although correct, isn't, it's wider.
Paul![]()
Regarding the smoke and rough running, was it like this before you started work on it?
Oseanosea
I would think it would be more a matter of worn piston rings than a gasket issueifinallyhaveane30 wrote: ↑Thu Jul 18, 2019 9:17 amA better question would be what seals would one recommend replacing to stop oil from leaking into the cylinder?ifinallyhaveane30 wrote: ↑Wed Jul 17, 2019 8:55 amTo follow up, the loud ticking audible in the video was due to me not tightening the eccentric bolt down enough. The gap was enormous. I completed another valve adjustment and the car runs pretty rough. Sputtering, rough idle. Slight lack of power. Very light white smoke (or moisture??) coming from exhaust.
“Keep lowering your standards until goals are met.”
ifinallyhaveane30
No. The rough running happened after I adjusted the valves and left one of them SO loose. The gap must have been numerous mm. Lol.Supafly wrote: ↑Thu Jul 18, 2019 9:39 amI had this issue on my m20 too. I would measure them and they would be within spec but I could feel the extra movement in the rocker, it was only when I turned them around to expose the contact face that I saw the pitting. New eccentrics (cheap at the time) fixed it for me.paultv wrote: ↑Wed Jul 10, 2019 12:28 pmYou may also have pitted eccentrics - worn from years of use, so they have a "cup" indent from the valve stem top, which you "bridge" with the feeler gauge, so the gap, although correct, isn't, it's wider.
Paul![]()
davidt
- Pompey Council 4 door deviant
I use one of these tools, feeler blade with handle makes it much easer to check clearances.
ifinallyhaveane30
ifinallyhaveane30
Update:
I purchased a sec of new eccentrics from ECS Tuning (they came labelled as Bav Auto brand, but I'm not really sure what brand they actually are) and installed them last weekend. Upon removing the spark plugs, I noticed that the plug in cyl. no. 2 was damaged. The gap had been reduced to 0mm due to the plug being accidentally dropped on the last valve adjustment. With the side electrode bent back and the gap set properly, as well as new eccentrics, the car runs MUCH better. Stronger power, responsive throttle, and a smooth idle once again. The only issue is it seems like maybe one valve is still a bit loud. Maybe next time I dig in I'll fix it. Does anyone know about adjusting the valves on one cylinder, or must all six be adjusted at the same time in accordance with the firing sequence?
