My 4 speed auto box "jerks" badly when I engage any gear and it seems to be getting worse, all other operations of the box are spot on, changes up and down fine, kicks-down well, slides into top just over 50mph for motorway cruising.
The fluid level is a touch high but don`t think that's the problem, I have also noticed a slight "movement clonk" when slowing/pulling up so think I may have worn bushes somewhere ? or is it what I have heard in the long distant past that the "brake-bands" need adjusting ? any ideas welcome, especially from any auto experts, cheers.
318i Automatic gearbox issue
Yes, I agree. I had a ‘73 2002 automatic with same issue. Turned out to be the universal joint on the driveshaft had gone bad. Replaced it, all was good again.
“Keep lowering your standards until goals are met.”
