Driver side washer jet spitting
Foe
Post Sun Jun 30, 2019 4:50 pm
So my passenger washer jet squirts out with power, however my driver's side is more like a small rodant spitting. It just dribbles out.
Checked all the hoses and all is well.
Anything I'm missing?
Anything else I need to check?
Ta
ChrisHC
E30Zone Contributor
Post Sun Jun 30, 2019 5:31 pm
Almost certainly a bit of grit is stuck in the nozzle. Take it off and poke with a fine needle, suck and blow at it.
Steve
Jet is probably blocked, I normally just stick a pin down it to clean it out.
webmaster@e30zone.net
Foe
Post Sun Jun 30, 2019 5:49 pm
Sometimes it's the most obvious things!
Post Sun Jul 07, 2019 2:41 pm
I have just had the same thing on mine. I took off the jets and blew them out at work with air but also cleaned out the washer bottle as it was full of crap !!
I now intend to replace the plastic water pipe for what it costs and to keep the system clean with "decent" washer fluid not the asda/tesco blue shit !!
Foe
Post Sun Jul 07, 2019 7:32 pm
martauto wrote: ↑
Forgot to follow this up. I did the needle poking, but it's still the same. I think I need the jets off, as you did, and try that. :thumb:
Post Mon Jul 08, 2019 3:20 pm
I would take the bottle out , a five min job , clean it and replace the tube and you are good to go for another 20 years.
Foe
Post Mon Jul 08, 2019 9:30 pm
martauto wrote: ↑
Good idea, and my next job. I will update. Out of interest, where did you get the washer tubes from, and are you using the original clips?
Post Tue Jul 09, 2019 3:03 pm
Tubing from e-bay and I think the clips are still in place so when it arrives I will let you all know.
Foe
Post Tue Jul 09, 2019 9:22 pm
Excellent thanks Mart :thumb:
Oseanosea
Post Wed Jul 10, 2019 6:08 pm
I’ve had difficulty finding the proper diameter clear vinyl tubing with the white webbing reinforcement on ebay, or anywhere so far. Perhaps I am searching for it using the wrong terms? I currently have a patchwork of different tubings & connectors. Would love to tidy it up. If someone has a source or link to a tubing they’ve used and found suitable, could they please share it? Thanks, Sean
“Keep lowering your standards until goals are met.”
Ozu
Post Wed Jul 10, 2019 8:21 pm
IMHO you’re barking up the wrong tree. You need to get a new one of these from your local dealer or Jon at Cotswold BMW. It’s the non-return valve and it looks like this
https://share.icloud.com/photos/0Y17dwf ... ne_-_Brook
Oseanosea
Post Wed Jul 10, 2019 10:05 pm
Thanks Ozu, not sure if you meant your message for me, but it’s handy to demonstrate what type tubing I’m looking for!
Foe
Post Sat Jul 13, 2019 9:25 pm
Quick update.
Cleaned the nozzles and washer tank.....spits followed by froth, then nothing! (Driver side, as passenger side perfect)
I assume, return valve failed, or a pipe split in the driver's side pipe?
Also asked a few times. Anyone have a link or recomend where to get the washer fluid pipes from?
BenHar
Post Sat Jul 13, 2019 10:41 pm
Have you asked the dealers?
Ben
Foe
Post Sat Jul 13, 2019 10:48 pm
BenHar wrote: ↑
Ben
I think the older I get the more stupid I become!
Certainly sounds like a good place to start :wink:
Post Sun Jul 14, 2019 12:25 pm
I just replaced the whole lot with 5mm ID clear tubing from the bay for £4 , does a job and only took 1/2 hour tops.
Foe
Post Sun Jul 14, 2019 12:48 pm
martauto wrote: ↑
Thank you :thumb:
Post Sun Jul 14, 2019 12:56 pm
Oh and I kept the two clips and just ordered a one way valve for £2 from the bay.
chatstar123
Post Mon Jul 15, 2019 12:33 pm
Mart, how much tubing is required?
sweep
Post Mon Jul 15, 2019 6:13 pm
Have you tried the jets with the bonnet up to see if the valve is leaking?
If not - disconnect the pipe work to the washer jet and airline it through that should solve your problem but make sure pressured air comes out of both nozzles . On the suspect jet.
Foe
Post Mon Jul 15, 2019 8:01 pm
sweep wrote: ↑
Hello
A good point. I've just tried it and the valve is leaking badly.
sweep
Post Mon Jul 15, 2019 8:19 pm
That’s your issue then as it regulates to both jets the same amount of water
Foe
Post Mon Jul 15, 2019 8:56 pm
sweep wrote: ↑
Thanks :thumb:
Foe
Post Mon Jul 15, 2019 10:32 pm
If anyone is after some braided hose, found this on the bay, seems good and tough!
Post Tue Jul 16, 2019 12:55 am
chatstar123 wrote: ↑
I bought 5 meters for less than £4.0
Gert_8
Post Tue Jul 16, 2019 4:07 pm
Oseanosea wrote: ↑
I bought tube from the dealers and they supplied it in black....
