hi all,
been through lots of threads but struggling to pin point a answer.....
i have a 1989 320i cab and am going to lower it 40mm all round.
can someone recommend a half tidy set of springs and shocks??
dont want top top end range but certainly dont want lower range either.
just a good brand for day to day use ??
thanks
matt
lowering recomendation
Cloggy Saint
mm1067
that's what im going to order then....Cloggy Saint wrote: ↑Sun Jun 23, 2019 11:56 pmIf you're lowering 40mm you can get away with keeping the original shocks unless they need replacing. You can't go wrong with the tried and trusted combination of Eibach springs and Bilstein B4 dampers.
one more thing .....sounds silly but... will the car sit level all the way through if I lower 40-40 or should I do 40 at the front and 30 at the back ?
sounds a bit silly but im wondering why most springs lister are 40-30 and not 40-40 ?
thanks again
tha881
mm1067
car looks lovely mate!
cheers for your input
