Hi guys,
On the hunt for a new thermostat, and just wondering if you think for this part it is worth paying the £70 OEM price vs the £20 aftermarket price? Usually buy BMW parts, but due to the simplicity of this part it has me wondering...
Appreciate any experience or thoughts on the aftermarket ones.
Cheers,
Jo
OEM Thermostat vs Aftermarket Febi, Motorad, Gates etc
BristolE30
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Foe
I used Cotswold on here in the sales section. It was better quality than the one that was in the boot as a spare.
There is that saying, you pay for what you get.
Not sure if it applies to everything, but for the majority.
The OE thermostat fitted to E30s and the E36 and E34 models was actually one to avoid. They suffered from one side of the bridge piece that holds the wax capsule fracturing, so that the valve closed at an angle, letting coolant though when it should be closed, causing slow warm up and cool running when lightly loaded.
MyOtherCarIsAnE30
I went with the Febi part and have had no problems, its been on for a year.BristolE30 wrote: ↑Mon Jun 17, 2019 4:08 pmHi guys,
Cheers,
Jo
BristolE30
That's interesting! Guess that answers this question then. Thanks Brian.Brianmoooore wrote: ↑Mon Jun 17, 2019 6:52 pmThe OE thermostat fitted to E30s and the E36 and E34 models was actually one to avoid. They suffered from one side of the bridge piece that holds the wax capsule fracturing, so that the valve closed at an angle, letting coolant though when it should be closed, causing slow warm up and cool running when lightly loaded.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Steve
Just to add, the last thermostat I bought, had a tiny ball bearing in it, which made it hell of lot easier to bleed.
Like this one -
Like this one -
webmaster@e30zone.net
reggid
wahler brand
E30 325is with M20B31
BristolE30
Went with a Febi one, opened the box and turned out to be a Calorstat. Working well so far.
Old Thermostat looks like this:
What is that stuff!? It’s rock hard.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
