So there is a pipe 'dangaling' from the throttle body. Any idea where this goes?
1991 316i.
Pipe from throttle body
Cloggy Saint
Foe
The end of the pipe is blocked off. And thanks for the reply
paultv
I reckon it's one of the vacuum advance retard pipe connectors for the distributor fitted to a few very early models - it has a short blanking tube ( rubber, which rots out and lets in air ) attached on all other models,
The short metal pipe drops from under the mounting flange of the throttle body and should have a stubby rubber blanking tube push fitted on.
If you look behind your alternator you'll see the blanked off fitting point for the not needed mechanical distributor on the side of the block.
I think there were two advance/retard pipes fitted to these very early cars but I'm sure Brian will show up and clarify this and all the rest if I'm wrong!
Paul
Paul
Cloggy Saint
paultv
No, I meant an early 80's car, but obviously no longer used, therefore the dummy block off.
but I'm probably mistaken anyway...
Paul
Paul
Foe
Thanks for your help gents.
It doesn't seem to affect the running, just annoying that there's this pipe, going no where!
Cloggy Saint
Foe
Will do and thanks both
paultv
This is the official stubby tube:
11611727176
https://www.leebmann24.de/verschlusskap ... gLGP_D_BwE
or:
https://www.ebay.de/itm/232467348264?ul_noapp=true
Paul
11611727176
or:
Paul
Foe
So, following up on this, there is also this wire with an un-plugged connection. We have no idea where this goes, or what should it should plug into into?
We're going to replace the thermostat, for an OEM one as the fan is not kicking in when the engine get s hot.
Any ideas?
Any ideas?
