Hi zone
This is on a 325i cabriolet
I'm having a nightmare of a job getting these Bushings in, I've got a set of superpro bushes to put in. I know these are notoriously a pain but these seem even harder!
Anyone have any tips on getting these in? They're lubed up to the hilt!
Superpro Antiroll bar bushes
BenHar
Front? Rear?
Definitely got the right ones for a cabriolet?
Ben
Ben
BenHar
The cabriolet has a thicker front anti-roll bar than any other E30 (21mm). So you need the correct bushes.
But they are a tight fit on all of them.
You can try and pull the clamps together with water pump pliers or something or use longer bolts to get them seated and then replace with the correct bolts.
Ben
Ben
MiniC
Ah just looked up my packaging they're 19mm which is obviously too small I'll have to get the others thanks guys
