rear drop link replacement
steve_k
Post Tue Mar 05, 2019 9:45 am
morning folks,
going to be replacing the rear drop links on my sport in the next day or so (old one's are worn out).
got a set fitted with poly bushes, now the thing is one end has a metal sleeve & the other don't.
so, does the end with the sleeve go roll bar end or trailing arm end?? or don't it matter??
chatstar123
Post Thu Mar 07, 2019 5:48 pm
I would say the metal sleeve would be for the trailing arm but don't know for definite.
Post Thu Mar 07, 2019 6:16 pm
chatstar123 wrote: ↑
I agree with the above. The arm end of the link is secured with a nut and bolt, which needs something (the sleeve) to tighten down on.
steve_k
Post Thu Mar 07, 2019 6:24 pm
thanks guys, thankfully the poly bushes i've got have got metal sleeves both ends which helps as i have eibach adjustable arbs so it's bolt through both ends.
