Short shifter
fastandloud
Post Tue Feb 26, 2019 3:41 pm
Has anyone fitted one of these short shifters
ChrisHC
E30Zone Contributor
Post Tue Feb 26, 2019 8:55 pm
Have you read the wiki on the subject? LINK
steve_k
Post Wed Feb 27, 2019 8:30 am
who's it from?
i fitted a B&M short shifter a few years ago, was pretty straight forward,
if your e30 still has the vibration damper (big rubber covered metal ring on the prop coupling) then remove it as it saves having to bend the selector rod, also if you can couple the short shifter with a DSSR (dual shear selector rod) it will take out a lot more slop.
