320i cold idle issues
keith2874
Post Fri Feb 15, 2019 9:47 am
Hi there
I have a 1990 320i which has a cold idle issue
When you start it it is overfuelling and can easily flood - it then hunts for the first few minutes but once warm runs fine with no issues
It's had a new blue sensor and we've checked for air leaks but found no issues
Does anyone have experience of this and if so what should I be looking for next? I have heard sometimes issues like this are related to a corroded multiplug on the engine or dodgy AFM but really would appreciate any pointers before we start pulling it apart again.
Regards
Keith
arrisbmw
Post Tue Feb 19, 2019 10:28 pm
could well be your idle control valve , needs cleaning .
next check tps is set correctly.
then the obvious plugs. leads and rotor arm and dizzy cap are good condition.
arrisbmw
Post Wed Feb 20, 2019 12:45 pm
then i,d go fuel pressure . leaking injector possible
TheWolfman
Post Thu Mar 28, 2019 11:24 pm
Just wondering if you got anywhere with this at all?What you describe is basically exactly the same issue I have on a '84 Baur 320i.I suspect it's an issue with my cold-start valve (air slide valve) ,which is very different to what you have on the later E30 though.
