ABS Relay
PattheCat
Post Thu Feb 14, 2019 8:48 pm
Hi everyone,
I'm having ABS Relay issues after using my e30 to jump another car (I now know this is a no, no! 8O ). My car is a 1988 so I removed the ABS relay and checked the internal fuse which was blown. I've tried the bodge fix of adding an 8 amp fuse in place of where the original fuse element was, but the fuse blows instantly when the ignition is turned on. BMW don't sell replacements anymore and i can only seem to find a replacement from Germany for ~£35.
Before I hit purchase, has anyone else had their relay blow and the 'add a fuse' fix didn't work? My only worry is that I wait for this to turn up only for the relay to pop again!
Any help would be appreciated!
Bonus Image
Post Fri Feb 15, 2019 1:42 pm
There is a zener diode inside the relay which conducts on voltage spikes, shorts the supply and blows the fuse. The zener diode should normally survive this, but it looks like yours might have paid the ultimate price to protect its ABS ECU.
Post Fri Feb 15, 2019 4:00 pm
There you go and welcome to the zone as well mate !!
PattheCat
Post Sat Feb 16, 2019 11:57 am
Thanks Brian, I just tested the relay using a spare car battery and you are right, it's dead as Dodo. Will grab another one and hope that the ECU survived!
Cheers Mart!
