320i Auto to manual conversion
swin
Post Tue Jan 08, 2019 8:20 pm
Hi,
I have an 1989 320se auto that at some stage was converted to 325. I now want to convert it to manual.
I have pedal box pipes wiring etc done as far-2 slave cyc and have a 320 manual gearbox flywheel etc ready to go in.
My question is I have a manual 325 prop will this work or do I need a 320 propshaft?
Thanks in advance,
John
Post Tue Jan 08, 2019 11:30 pm
If you are using the 320 'box, then you need the 320 prop. Similarly, 325 'box needs the 325 prop.
