Factory A/C Evaporator Removal Steps for RHD E30 Auto
ayek
Need to replace the a/c evaporator due to leaky. I have lowered the steering column/shaft but it still stuck at the brake pedal. Appreciate any advice on the removal steps,
I dont know but have you had a look in our "wiki" ??
ayek
Thanks Mart. None in wiki. I found some sharing in other forum but for LHD car which is quite straight forward without the steering shaft and pedal on the right side. Anyhow, I managed to force it in after much difficulties. I'm sure some of the fins are damaged on the way in.
