High idle
fastandloud
Morning all I've a 1986 318i m10 converted to 325i m20 from a 1989 donor car problem I have is on first start up the revs shoot up to 3to 4k then straight back down to 1k it doesn't do it after that until I start it again next day I've checked everything I can think of no air leaks or anything new icv fitted new blue temperature switch trottle body cleaned fuel injectors refurbished any ideas what could cause this
arrisbmw
sounds temp related. check the blue temp switch at the e.c.u . which also checks the wiring to and from it.
https://www.e30zone.net/e30wiki/index.p ... emp_Sensor
