icv only works for 2 seconds and engine dies if plip throttle
arrisbmw
Post Fri Nov 30, 2018 10:23 pm
Hi All.
Can anyone help please . M40 engine.
when the engine is stone cold , i start the car fires up fine approx 1500 revs
problem is it drops straight after a second or 2 to a 600 - 700 idle.
its been cleaned. blue temp sensor new and checked at e.c.u.
its like the icv is not getting enough power while the engine is warming up.
any ideas appreciated. I changed the e,c.u too . same issue.
arrisbmw
Post Mon Dec 10, 2018 8:21 pm
ANYONE ? JUST WANNA ADD when idling with stonecold engine if i blip the throttle engine dies .
any ideas please please.
when engine warm , no problem. m40 1.6
Shutthatdoor
Post Mon Dec 10, 2018 8:29 pm
It's not the element in the MAF that's at fault? Can't think of anything else if you've cleaned and checked for leaks etc
arrisbmw
Post Mon Dec 10, 2018 10:49 pm
thanks for the reply , but my e30 has not got a mass airflow meter , and i don,t think any have . we have afm . older design.
i,ve chexked and cleaned that all seems o.k
arrisbmw
Post Tue Dec 11, 2018 7:58 am
the only thing i thought is have a got a bad inlet manifold gasket where the I/M meets the head, ? dont know how to test this theory
as the engine warms up and expands it seals it. as i don,t have a problem when at running temp.
