Suspension setup and alignment
BattleBoiNZ
Post Fri Oct 12, 2018 5:31 am
Hi guys your advise please. I’m having problems with my suspension setup. Have bilstein shocks and shocks all round.
#1. I rebuilt the rear end with new sub-frame, trailing arm, spring perch and diff bushes. Had a wheel alignment which is giving me neg toe of left 5mm and right 3.5mm.
#2. Front I replaced strut top mounts, spring perch bushes, rear control arm bushes. RH side camber is within spec but LH is -2.25deg. I’ve checked for damage by PO but nothing obvious.
[/img]
