Trouble getting the drive shaft through the hub!
Tedswagon
Post Mon Sep 10, 2018 12:46 pm
Hopefully some of you can shed some light on a problem I had this weekend.
I put the drive shafts on, pushed the splines end into the hub - then bolted up at the diff. Both sides. Then through tapping the hub and jacking up the trailing arm coaxed the threaded end of the drive shaft through the hub . . . on one side only!! 8O
The other side - no end of tapping the hub - tapping the drive shaft from the diff side would get it through enough for a thread to be visible to the out side. I pulled the drive shaft off and with a wire brush got the splines spotless clean - then some more copper grease and attempted again - still not going in enough to get the nut on it.
Any advise please on how to get this through? I need to get the wheels back on so I can get the car out of the garage.
sweep
Post Mon Sep 10, 2018 8:35 pm
Did you warm the old collar up to remove it from the hub flange?
Tedswagon
Post Mon Sep 10, 2018 10:59 pm
No, I bought the hub off someone on the zone fb page. Hub looked good when I got it.
Post Tue Sep 11, 2018 9:14 am
Wouldn't it be best to remove the driveshaft from the diff, then attempt to insert it into the hub?
Tedswagon
Post Tue Sep 11, 2018 1:06 pm
Speedtouch wrote:Wouldn't it be best to remove the driveshaft from the diff, then attempt to insert it into the hub?
When I had the drive shaft and hub off the car - i put them together to see if they lined up. Which they do. I then put the hub into the wheel bearing and then put the splines of the drive shaft into the hub, I couldnt push it in but it is lined up. So I bolted the other end of the drive shaft to the diff, then jacked up the trailing arm. This method worked on the drivers side enough for me to put the nut on the end of the shaft - tightened it up and all looks good. On the near side it pushed the splines end through the hub approx 3/4 way through, not enough to get the nut on the end of the drive shaft. So that is where I am now.
Post Tue Sep 11, 2018 3:06 pm
Maybe it just needs a bit of lube, such as WD40, etc...
Tedswagon
Post Tue Sep 11, 2018 6:22 pm
Speedtouch wrote:Maybe it just needs a bit of lube, such as WD40, etc...
I lathered it in copper grease. Maybe WD would have been better! I'll strip and try that. Cheers
Post Tue Sep 11, 2018 6:41 pm
Perhaps try removing the driveshaft and leaving it in the freezer for a few hours, to contract the metal a tad...
Tedswagon
Post Sun Sep 16, 2018 8:53 am
Fixed it!!!@ looks like the hub had been pushed out so some turning oof the shaft and hammering oon the outside of the hub got enough thread to get the nnut on. Thanks for your suggestions Maurice and aall.
Post Sun Sep 16, 2018 10:38 am
Good to hear you got there in the end. :)
