Squeeky power steering belt!
MiniC
Post Sun Aug 19, 2018 12:03 pm
Hey zone I've replaced my power steering belt with a contech one the only problem is it squeeks really badly when locking at slow speeds, I've tightened it is much as I can to the end of the adjuster but it's still abit loose is there something else I can do to tighten it further??
Satan
Post Sun Aug 19, 2018 2:24 pm
Have you checked the fluid?
MiniC
Post Sun Aug 19, 2018 3:17 pm
Fluid is good
Gavt
Post Mon Aug 20, 2018 8:23 am
Maybe the wrong size belt. If it's maxed out on adjustment. And a slight squeak on lock is normal as the pump is fully loaded with no where for the fluid to go.
arrisbmw
Post Mon Aug 20, 2018 12:28 pm
did you compare the belt length with the original. as previous post said could be slightly bigger.
MiniC
Post Mon Aug 20, 2018 1:10 pm
Yeh it was good it's only got the 2 pulleys as its a chromie
Tedswagon
Post Mon Aug 20, 2018 9:38 pm
Might seam daft - try putting it on the other way round
I had a problem with an AC belt on another car after the original was put back on the wrong way round and it squealed. swapped it back and it was a lot better - wasnt a total fix - so just replaced in the end.
Alternative is to spray with a wee bit of silicone spray. lol
