The actuator is fine, the cable end at the drum on one side has a damaged/broken return spring -
Just to confirm my worst fears, is the cable NOT removable without pulling the outer sleeve from the car - in other words, pulling the inner out at the wheel, and feeding a new one in?
It says you can do this in Bentley, but in practice all is jammed up at the point where the outer meets the body....
any advice welcome
Paul
