Viscous fan
ETERNITY
The viscous fan comes in after 5 mins of driving
It’s stays on and drowns the engine note and slows down the performance and deaccelaration is prolonged
It’s a loud whining sound as the engine rpm increases
I Have changed the radiator and fan coupling/clutch and still have the same problem
I have bought a thermostat but not changed yet because I tested the previous one and it seems fine but was Checked at boiling point (kettle)
Puzzled?
Puzzled?
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
paultv
If your temps are good, maybe the old fan coupling was shot, and the new one needs running in, they tend to be "hard coupled" for a week or two depending on usage, then they loosen up and only spin when hot.
Cheap eBay viscous fans are known not to perform correctly in our cars best to buy OEM if possible.
Paul
Paul
ETERNITY
I bought a BGA (bullsye)
Thanks Paul
Thanks Paul
arrisbmw
thats strange never heard mine, before or after fitting a new viscous coupling.
my old one was knackered try the rolled up magazine test.
I suppose if your worried about performance , electric fan gotta be the way to go,
ETERNITY
Performance is affected because there seems to be a lag when the fan is on and making that jet noise
Theres a fault that I can’t figure out and neither can the mechanic
paultv
Is the car sounding normal when run without the fan belt for a quick test?
Paul
Paul
ETERNITY
Haven’t tried that yet
So undo the fan belt right and run it
Good way to check Paul !paultv wrote:Is the car sounding normal when run without the fan belt for a quick test?
Paul
ETERNITY
You dont have to go very far and you will know pretty soon.ETERNITY wrote:Haven’t tried that yet
paultv
Yep, loosen the alternator, get the belt off, you can finagle it over the fan and get it out - then start up and listen. This will take the viscous fan, water pump and alternator bearings out of the equation -
I fitted a cheap viscous a while ago - the car sounded like an F1-11 taking off and it refused to loosen up, so bought a Behr which cost twice the money but worked fine.
Paul
Paul
arrisbmw
i would not drive the car without the water pump will overheat very quickly. as no coolant is being pumped around
M3KUK
Yes mine is noisy too, cheap one off ebay, would buy a named brand next time.
Like Paul said, it`s only for a few seconds and you dont even have to drive it, just see how it is without it.arrisbmw wrote:i would not drive the car without the water pump will overheat very quickly. as no coolant is being pumped around
ETERNITY
I just did the same and mine and replaced it with a behr and it still sounds like a jet. The sound and interference with the performance is annoying.paultv wrote:Yep, loosen the alternator, get the belt off, you can finagle it over the fan and get it out - then start up and listen. This will take the viscous fan, water pump and alternator bearings out of the equation -
Paul
The sound is loud and I can feel a drag from the fan
Not sure a¤” where to go from here.
paultv
it will take a few days to loosen up - they are pretty sticky out of the box
Paul
Paul
ETERNITY
Ok hopefully engine noise will go back to normal and I can enjoy the m20 note
