Recently my e30 318i has encountered an annoying problem when selecting reverse. Only sometimes, the car will get stuck in reverse, I mean it's so stuck you can't move the shifter unless you stall, plus, even if you have the clutch pressed flat to the floor, the car will try to reverse and try to stall. Other than that, the clutch doesn't seem to slip, but does have a chatter every now and again (which I though was normal given the age) and sometimes the idle can be a bit sluggish when putting the car into neutral. I'm just wondering if anyone has had any similar issues, and can give me the heads up before I start paying mechanics to look where they may not have to
My car is a manual e30 318i UK version if that help.
Thanks all.
