New MOT rules headlight adjusters fail
terryjippo
Post Mon Jul 02, 2018 10:38 am
Morning all,
Just had my E30 fail MOT on the headlight height adjusters. All my previous E30s (facelift) all had this issue, aka the headlight adjusters are usually seized so didn't bother sorting it but now apparently it is now a fail with the new mot rules.
I normally set the headlights manually once I've freed the adjusters but never bother getting the rest of the system working as imo it just isn't worth the hassle.
I'm wondering whether to get it all working correctly, or shall I just remove the adjuster dial where it's located under the dash?
Thoughts?
Not exactly OEM but then the car is more running resto jobber than most of them on here ;)
Billy
Cloggy Saint
Post Mon Jul 02, 2018 11:19 am
I always remove the height adjuster switch for the mot and replace after.
Satan
Post Mon Jul 02, 2018 11:48 am
Remove the system totally and put a replacement under dash panel in.
Satan
They want old turds off the road.........
aimlessrock
Post Mon Jul 02, 2018 3:13 pm
Satan wrote:Remove the system totally and put a replacement under dash panel in.
+1 did the same to mine also.
E30 320i Convertible (1989)
190 Mercedes (1988)
terryjippo
Post Tue Jul 03, 2018 10:18 am
Satan wrote:They want old turds off the road.........
This one is certainly that. But current values say its JUST worth keeping going. As I said, running restoration...
