Where to buy SI battery’s?
Danfisher19
Post Wed Jun 13, 2018 11:19 pm
Hi,
I think I need to change my SI battery’s behind my cluster. I have done all the usual checks... brass nut, earthed correctly etc so I feel this may be the next step.
Does anyone know where I can get the battery’s with the prongs on? I can source them from the states but these don’t have the prongs on I would also (for obvious reasons) like to get them from the uk.
Thanks a lot.[/b]
minesapint
Post Thu Jun 14, 2018 12:59 am
CPC-Farnell. Read this from the Wiki, especially the section, replacing SI batteries.
http://www.e30zone.net/e30zonewiki/inde ... nstruments
TurtleDesignTech
Post Thu Jun 14, 2018 8:54 am
I got mine from here. Fitted and working perfectly:
https://secure.reichelt.com/gb/en/?ACTI ... =CR14250SE
arrisbmw
Post Thu Jun 14, 2018 3:20 pm
for my info. what are the symptoms of failing batteries, I know if yon don,t remove/ replace dead ones can leak causing no end of problems.
Danfisher19
Post Fri Jun 15, 2018 5:41 pm
Excelent thanks very much, am i right in thinking that whatever battery's my car had out of the 2 i will be fine replacing them with the battery's from cpc-farnell?
Contours
Post Sat Jun 16, 2018 9:55 am
They would have to be the same type and voltage. Mine are 1.2 volt Ni Cad but lithium were also available I think in later models. You do not have to be a genius at soldering either to wire a battery pack outside of the cluster altogether attached to the connector points on the circuit board. This would save you having to remove the cluster every few years to replace the batteries and also you do not need to source batteries with tabs on them.
Post Sat Jun 16, 2018 1:29 pm
arrisbmw wrote:for my info. what are the symptoms of failing batteries, I know if yon don,t remove/ replace dead ones can leak causing no end of problems.
The symptom I had with failing batteries was that after re-setting the service indicator lights every few days they would revert to inspection light showing again.
