Hey zone.
I've got a very bad clunking I can feel through my steering wheel I can only feel it when in turning at very low speeds and it's awful if I'm stopped and turning the wheel. As always any help would be much appreciated.
Steering clunk
Satan
Does the wheel feel "loose" when you move it side to side when stationary? Mine was and the rubber in the steering UJ had perished.
MiniC
It feels fine u til you put it under load about half a turn and it feels like it's bouncing off the power steering
Satan
Have you checked the power steering fluid?
MiniC
Yeh there's plenty in it. It is very old mind you
brutus
,, ive seen this before,,,
OLD oil,,its
probably best to drain or suck out as much & and replace,
OLD oil,,its
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
MiniC
Ah alright ill do that. As far as I'm aware it's been the same for atleast 15 years a˜‚
arrisbmw
when is m.o.t due ? their spot the issue.
get the front of the ground and , shake the wheel at hands at 3 and 9
then 6 and 12 . while someone else is looking under the car at all ball joints and front suspension components.
you might be able to hear a knock. while your their check steering rack is fixed solid bolts tight and play in outer or inner tie rods ( on each end steering rack )
