Received a hub/ bearing for the front but it's am abs one is it OK to put on or are they not compatible?
Are abs wheel bearings compatible with non abs?
Gogogomez
I just used some pullers to remove the abs teethed ring then they will fit fine. You have to remove the ring if you have non abs model I believe.
BHadley
Same here just remove the ring
