stripped thread help.
steve_k
Post Fri May 25, 2018 6:56 pm
evening folks looking for a bit of advise.
went to do a mates cambelt on his m20, when i went to remove the upper timing cover i noticed that on the bolts which holds both the upper cover & lifting eye had be helicoiled before & not very well as the coil was still on the bolt when i took it out.
thing is, what the best option to proceed with? retap it & use another helicoil?
or drill it out & retap it to M8 size?
got all the bits here to do either so just wondering which route folk think is best?
steve_k
Post Sat May 26, 2018 9:25 am
anyone?
Scotty200
Post Sat May 26, 2018 9:49 am
Personally for me if there is enough meat around the hole I would go the drill and retap less chance of the threads pulling out again at a later date
steve_k
Post Sat May 26, 2018 10:06 am
Scotty200 wrote:Personally for me if there is enough meat around the hole I would go the drill and retap less chance of the threads pulling out again at a later date
thats what i was thinking, will have a god look today & see if there is enough there to drill it out & retap it.
Satan
Post Sat May 26, 2018 11:14 am
As above, better a proper job then a bodge.
steve_k
Post Sat May 26, 2018 1:37 pm
well it's all done now, used the correct tap & recut it to M8 size, also did the other side while i was there so they both match up.
Post Sat May 26, 2018 3:55 pm
steve_k wrote:well it's all done now, used the correct tap & recut it to M8 size, also did the other side while i was there so they both match up.
Just seen this Steve and thats exactly what I would have done and full marks for doing both sides as well mate !!!
Mart, toolmaker by trade.
paultv
Post Sat May 26, 2018 4:24 pm
I have the same issue, looking at the engine from the front its the left hand bolt that runs thru' the lifting eye and into the head? its a bolt with a long shank and end thread if I remember - so M8 is the next tap up? I need to do mine, is there any issue with swarf from drilling, internally I mean?
Paul :-)
Post Sat May 26, 2018 5:09 pm
Dont know exactly but run the drill very slow and put grease on the bit to try and hold onto the cuttings making sure you clear the bit often.
steve_k
Post Sat May 26, 2018 6:30 pm
@mart, cheers dude, had a big tub of grease so dipped the bit & tap in it before going very slowly with the drill.
@paultv, thats the one i had to do, M8 is the next step up & a lot stronger when you consider that the engine hangs off there on a hoist.
Satan
Post Sat May 26, 2018 7:35 pm
Tallow for threading,
