Z3 rear sway bar swap to E30
BattleBoiNZ
Post Fri Apr 06, 2018 9:47 am
Help/advice please. Has anyone attempted to fit an bmw oe non-e30 ie Ti or Z3 rear sway bar to an E30s?
I’m in the process of replacing subframe and trailing arm bushes and discovered there is no sway bar (strangely given a PO went to the expense/trouble of upgrading to bilstein springs and shocks). Anyhow I was after a bar a stiffer than 12mm and more M3esk 14.5mm (going to aftermarket 16mm I expect will mean reinforcing the trailing arm tabs and stiffening up the front to compensate as well as a lot more cost).
Issue 1 - So I’ve got on trial a z3 1.9 14mm bar. Brackets fit no problems but the kink in the back of the bar doesn’t line up with the diff hanger and bar fouls the pressed crease in the hanger. Have tried fitting both ways but fouling is only worse. I could ”˜modify’ the hanger (hammer/grinder) but I expect this may compromise the stiffness/integrity of the hanger.
Issue 2 - note also that the arms of the z3 bar are longer than an e30 but the links are shorter which compensates? Until I have the car back on it’s wheels I won’t really know if this will be a problem.
