how to test a A.F.M in situ
arrisbmw
Post Mon Mar 05, 2018 2:34 pm
Hi Can Anyone advise me how to check my air flow meter is working o.k. on a 89 m40 engine . the plugs looked a bit black and not getting good mpg, so wondered if mixture is too rich, and is this component working correctly.
thanks in advanced.
arrisbmw
Post Wed Mar 07, 2018 10:12 am
anyone ? .. thanks,
when i checked my flap its moving in and out with little resistance.
I double check my mpg. may be not as bad as i first thought 7.5 miles per ltr.
anyone got their mpg ? or miles per ltr please .
BenHar
Post Wed Mar 07, 2018 5:15 pm
arrisbmw
Post Wed Mar 07, 2018 7:16 pm
cheer Benher. good post.
Post Wed Mar 07, 2018 11:16 pm
7.5 miles/litre = 34 MPG, which isn't bad for an E30 in mixed driving.
arrisbmw
Post Fri Mar 09, 2018 7:35 pm
yes . i,m figuring now everything is o.k. after my tlc, new battery was the last consumable fitted.
but i,m still keen to learn amap about the car. (as much as possible). I like to know how everything works and fits together in the little beauty.
in the post about checking the afm. can that be done without taking the black square top off, if so are the terminal numbered , so you know where to connect the battery small 9v, and where to test voltage curve. mines under a round connector,
guessing i got 5 terminal
2 x for temp = resistance test ,
1 x for 12v live supply and 1 x ground .
1 x 5volt signal wire is that right ? thanks
Post Fri Mar 09, 2018 10:09 pm
Battery negative to pin 5, positive to pin 1, meter negative also to pin 5 and meter positive to pin 2.
Pins 4 and 5 are for the intake air temp. sensor, and pin 3 is the output from the CO adjustment pot.
arrisbmw
Post Mon Mar 12, 2018 2:55 pm
thanks very much. helpful as always. cheers Paul
