How to locate differential noise?
markus_74
Post Wed Feb 28, 2018 11:45 am
Hello,
I'm confuse is it my Differential that cause noise or my new tire?
I try to make a test, while my car down hill I put my gear on neutral and I also press my clutch(not necessary), I hope it is disengaged my engine from connected with gearbox and my diff.
The results the noise is still there and the loudest is at 40km hour.
I can not make conclusion is it my diff or my tire that make noise?
Or any better method?
Thank you
Markus
Contours
Post Wed Feb 28, 2018 4:50 pm
Differential noise usually starts at 40mph and gets louder as you accelerate and sounds like a loud drone coming from underneath the car. You should check to see if there is oil in there.
Post Wed Feb 28, 2018 10:56 pm
Tyre noise should change with different road surfaces.
