Hi
My temp gauge seems to have a mind of its own! It is all over the place and now its just stock on the max temperature. It had been working fine and I don't think the car is running hot.
Any ideas?
Thanks for your help
Nick
Temperature Gauge
- Brianmoooore
Loose or missing brass nut on the back of the instrument cluster case makes it read higher than it should, but not normally as high as max.
A short circuit to earth of the wire from the brown sensor to the cluster will make the gauge read max.
A duff brown sensor is an unlikely possibility. These are much more reliable than the 'blue' sensor, and would more likely make the gauge read low if faulty.
- Brianmoooore
Looked inside the cover? That's where the pin numbers are on UK E30s.
Otherwise, there's a diagram in the wiki.
- Brianmoooore
Sounds like a classic description of the symptoms of a loose brass nut, but there's no guarantees!jkundi wrote:Sorry to jump on your thread, but mines been acting up of lately. Seems to have a mind of it's own and when it calms down its 1 quarter up or just below half.
