I recently bought a 316 baur TC.
There were these parts in the boot, also some buts in the engine i dont recognise. one i think has something to do with the heater?
Please could you help me identify them?
yes i doBrianmoooore wrote:Do you have a manual choke control for cold starting?
Thanks for the reply Brian, yes it is indeed a Weber carb in there now. Is it best practice for me to remove the tubes and wires seen in pic 3? Not sure if it'll be causing a vacuum leak or something.Brianmoooore wrote:In that case, the original carburetor will have been discarded and replaced by an aftermarket one, almost certainly a Weber. The various unused and disconnected bits around the engine bay are parts of the automatic control systems for the original - a system that was fine when the car was new, but hopelessly unreliable after ten years, when I owned a 316 E30, and I doubt if a further twenty years has improved things.
Pic. 4 is an electric heater valve. Quite valuable if in good order, and there's no obvious sign yours has failed. You will have another one fitted to the car - one of the heater hoses connects to the black pipe where it pokes through into the engine bay.
