750i brake cilinder
mopsdrops
Post Mon Dec 18, 2017 9:25 pm
Hello,
Just got my new Wilwood 4-pot BBK and I'm planning to run a larger master cylinder (750i). Do I need a E32 or E38 one? Or are they the same? Is it a direct fit? (Clio brake booster)
Post Mon Dec 18, 2017 10:49 pm
E32 fits, or if you struggle I can supply a large bore cylinder for under £100 8)
mopsdrops
Post Tue Dec 19, 2017 11:31 am
Thanks! Struggle with finding one or fitting? Straight fit , right? You're from Great Britain, right?
Can such a master cylinder also cause an 'overkill' ? Or are you always good with a bbk and 25,4mm cylinder?
Will it also cause more force at the rear brakes? With other words, will i need a brake bias valve to prevent lock up at the rear with this cylinder? Thx
paultv
Post Wed Dec 20, 2017 10:39 am
It will create less force - larger bore= less hydraulic advantage, but harder pedal - if you work out the pressure at the caliper with a 22mm bore you get something around 1700psi but with a 25.4 you get 1200 psi - this for a pedal force of 200 lbs which apparently a bloke in a correctly positioned seat can apply.
So its all related to feel and pedal travel as well as ability to modulate - and how strong you are!
I think this is pretty useful:
http://www.wallaceracing.com/brake-master-cyl-calc1.php
Paul :-)
Post Thu Dec 21, 2017 12:14 pm
What wilwood kit is it? You need to know how much larger diameter the pistons are compared to standard to work out the best sized master cylinder, if you are keeping standard rears then yes you will need bias valve as they will be working before/more than the fronts
mopsdrops
Post Thu Dec 21, 2017 10:22 pm
Thank you Paul & DanThe for the good advice!
@ DanThe
It's Dynalite II 4pot (44mm pistons) ..... ?
Also, i sended u a pm about your larger bore cylinder, did u see it?
Kind regards
