Low rev idle
DazzyA
Post Sat Jan 28, 2006 3:28 pm
Car has recently been idling at 500 rpm's, have checked all pipes for leaks, renewed inlet manifold gasket and throttle body gasket, TPS is clicking ok.
Any other possible causes, she feels like she will cut out anytime, but doesn't.
Pass me the spanner
DazzyA
Post Sat Jan 28, 2006 3:42 pm
Makes no difference at all when I remove oil filler cap!
Pass me the spanner
DazzyA
Post Sat Jan 28, 2006 8:00 pm
It seems if you foget to put the bracket back on the rocker cover/inlet manifold ( lost the rocker cover bolts now) and leave the 2 bolts out of the manifold it don't like it. :oops:
Pass me the spanner
hammoj28
Post Sat Jan 28, 2006 9:21 pm
Hmm, yeah my 318is idles a bit low methinks. Bit of a lumpy idle. Im gonna replace the ICV (idle control valve) soon and see if that makes a difference. Dunno what they are meant to idle at though.
24v tech2
dark_sounds
Post Sun Jan 29, 2006 12:34 pm
DazzyA
Post Sun Jan 29, 2006 6:56 pm
It's ticking over better now, but at 400 rpm's. Changed the zone chip with the original and went up to 600.
Pass me the spanner
